Warning message
lost vlans
Jan 13th, 2006
Hi everybody,
My customer had a problem yesterday.
In fact, he has 1 Catalyst 4507 and suddenly the Catalyst 4507 lost his vlan configuration (only the vlans configuration).
The catalyst 4507 and the others switches connected are configured as VTP server but with a vtp password.
On the 4507 IOS there is no vlan.dat file on the flash.
So, I don't understand what happened.
Anyone has an idea what could be the reasons ?
Thank you for your help.
ankurbhasin Fri, 01/13/2006 - 02:30
  • Red, 2250 points or more
Hi Friend,
Can you confirm if 4507 is running redundant supervisor engines and did the active went down and standby tookover?
Ankur
mauricio9 Fri, 01/13/2006 - 07:32
Hi Ankur,
Yes, there are two supervisor engines and I suspect that the standby supervisor took over.
Do you think that there is a relationship ?
DWAM_2 Fri, 01/13/2006 - 05:48
what is the IOS version of 4507 ? (bug?)
when the behaviour occurs, is there an insertion of new switches ?
Regards.
acorredo Fri, 01/13/2006 - 16:03
  • Cisco Employee,
The VLAN database is not stored on the flash, it is stored on:
Directory of cat4000_flash:/
1 -rw- 676 vlan.dat
Don't know if you've taken a look there.
Usually something like that would happen if a new switch, with a higer VTP Configuration Revision, but an empty vlan database, is connected into the network.
mauricio9 Mon, 01/16/2006 - 00:43
The IOS version of the two sup are 12.1(19)EW.
I don't think that there is a bug with this IOS version but I'm not sure.
My customer said me that there wasn't any new switch connected.
What do you think if I propose to configure all the switches in VTP transparent mode ?
At the moment there are in VTP server with a VTP password.
Thank you by advance if you have any other suggestion.
Regards.
