Warning message
Catalyst Express 500 24TT linked to an unmanaged switch
Jan 13th, 2006
I'm trying to hang an unmanaged switch (netgear FS108)off this switch but with little success. I've configured the port on the Express 500 as a switch port but nodes connecting through the unmanaged switch can't fully browse nor can they receive DHCP addresses. Is there someway to make this work or are these Netgear switches simply not supported and won't work period?
acorredo Fri, 01/13/2006 - 16:11
  • Cisco Employee,
The SmartPort roles are designed to work with Cisco devices, you will have to try different roles with the particular switch you are using, please try the router role first.
cmorgan-mcgreg Mon, 01/16/2006 - 14:43
Yup, that worked. I assume the same issue applies to the 'server' port setting. If I've created multiple virtual servers each with their own unique IP address, the 'server' port settings spits back an error not allowing multiple connections through the same port.
