NATTING
Jan 16th, 2006
When using Nat on a router, Can you Nat any traffic that comes in, i.e if I have a router with a lan address of say 10.1.1.0 etc, could I nat say some 172.24.56.0 traffic that comes into the router ?
spremkumar Mon, 01/16/2006 - 02:35
  • Red, 2250 points or more
hi
You can try using ip nat outside source command where u will nat the outside source addres.
do refer this link for more info and the usage options/keywords..
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/ipras_r/ip1_i2g.htm#wp1079462
The below link inturn will throw more lite on a similar scenario..
http://www.cisco.com/warp/public/556/2.html
regds
carl_townshend Mon, 01/16/2006 - 03:06
So is this the normal scenero for doing this, and I gather the outside interface doesnt need to be on the same subnet as whatever addresses you are natting ?
