Warning message
PIX 7.0.4 NAT Issue
Jan 16th, 2006
I recently upgraded from version 6.3.4 to 7.0.4 on a new PIX firewall. Now it appears that mapping multiple outside IP addresses to a single inside IP, which was supported in 6.3.4, is not longer supported in 7.0.4. Is this true, and if so, are there any workarounds? Thanks.
PIX 6.3.4 Config
access-list acl_DMZ_in permit tcp 192.168.3.3 255.255.255.0 any eq 80
access-list acl_DMZ_in permit tcp 192.168.3.3 255.255.255.0 any eq 443
access-list acl_DMZ_in permit tcp host 192.168.3.3 host 10.250.225.25 eq 9080
access-list acl_DMZ_in permit tcp host 192.168.3.3 host 10.250.225.25 eq 9443
static (DMZ,outside) 172.16.1.10 192.168.3.3 netmask 255.255.255.255 0 0
static (DMZ,outside) 172.16.1.11 192.168.3.3 netmask 255.255.255.255 0 0
static (DMZ,outside) 172.16.1.12 192.168.3.3 netmask 255.255.255.255 0 0
PIX 7.0.4 Config
access-list acl_DMZ_in extended permit tcp 192.168.3.3 255.255.255.0 any eq 80
access-list acl_DMZ_in extended permit tcp 192.168.3.3 255.255.255.0 any eq 443
access-list acl_DMZ_in extended permit tcp host 192.168.3.3 host 10.250.225.25 eq 9080
access-list acl_DMZ_in extended permit tcp host 192.168.3.3 host 10.250.225.25 eq 9443
config term
ERROR: duplicate of existing static
DMZ-1:192.168.3.3 to outside:172.16.1.11 netmask 255.255.255.255
jackko Mon, 01/16/2006 - 18:47
  • Gold, 750 points or more
providing different static statements are used for different ports, you can configure port forwarding instead of one-to-one mapping.
e.g.
static (dmz,outside) tcp 172.16.1.10 9443 192.168.3.3 9443 netmask 255.255.255.255
static (dmz,outside) tcp 172.16.1.11 9080 192.168.3.3 9080 netmask 255.255.255.255
