NAC II labs setup
Jan 17th, 2006
Can somebody tell me what I will need to setup a labs for NAC II.I have a catalyst 2950 switches.Are they already included in the NAC framework or do I need to upgrade the image, if so which image should I download.
Will and upgrade be also necessary on the ACS. Till now I use ACS 3.3.
Thank you
Overall Rating: 4 (1 ratings)
lmilher_2 Mon, 02/06/2006 - 06:56
Hi Paltel, did you test ACS 3.3 in a NAC 2 switched implementation ??
Take care.
