How to test new PRI outbound
Jan 17th, 2006
How do I test a new PRI to make sure I can actually place calls outbound?
BACKGROUND:
We currently have 3 PRI’s installed on our 3660 for inbound and outbound calls. Last night I plugged a new PRI to make 4 and configured the 3660 like so:
controller T1 3/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
description Local T1
interface Serial3/0:23
no ip address
no logging event link-status
isdn switch-type primary-4ess
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
I went in to call manager and added the route group:
Then added the gateway.
I basically mimicked the configs that were already in place.
Now that everything is configured how to I test that specific PRI?
Overall Rating: 4 (1 ratings)
Hin Lee Tue, 01/17/2006 - 16:36
  • Cisco Employee,
Create a route pattern specific to your cell phone. For the Gateway or Route List select that pri you just added.
Sascha Monteiro Wed, 01/18/2006 - 13:26
  • Silver, 250 points or more
You'll better create a new Routegroup with only that gateway and put that RG in a new Route List.
Then create a test pattern like 8855.! pointing to that new routelist.
just use a 2,3,4 or 5 digit number that is free to use...
