01-19-2006 01:53 AM - edited 02-21-2020 02:12 PM
I have a problem with vpn client access and local ip pool. In Pix version 6.3x when i created ip local pool an object was also created under Hosts/Network and there was no problem to give this object (ip pool) access outside_access_in , but
in my ASA 7.04 there are no object created under Hosts/Networks. I have tried to use a filter (Filter_Av_10) under "Group-Policy" but i can´t get any traffic trough (see configuration below). It´s only working when i give the network 10.1.1.0/25 (ip pool) access outside_access_in (in Security Policy), is this the right way to do this?.
Could someone please explain this to me.
access-list Inside_access_in extended permit ip any any
access-list Outside_access_in extended permit icmp any any echo-reply
access-list Outside_access_in extended permit ip 10.1.1.0 255.255.255.128 192.0.0.0 255.255.255.0
access-list Filter_Av_10 extended permit ip 10.1.1.0 255.255.255.128 192.0.0.0 255.255.255.0
access-list easyv_av_butiker_splitTunnelAcl standard permit 192.0.0.0 255.255.255.0
access-list Outside_cryptomap_dyn_20 extended permit ip 192.0.0.0 255.255.255.0 10.1.1.0 255.255.255.128
global (Outside) 10 interface
global (DMZ) 10 interface
nat (DMZ) 10 192.0.3.0 255.255.255.0
nat (Inside) 0 access-list Inside_nat0_outbound
nat (Inside) 10 192.0.0.0 255.255.255.0
access-group Outside_access_in in interface Outside
access-group DMZ_access_in in interface DMZ
access-group Inside_access_in in interface Inside
access-group management_access_in in interface management
group-policy easyv_av_butiker internal
group-policy easyv_av_butiker attributes
vpn-filter value Filter_Av_10
split-tunnel-policy tunnelspecified
split-tunnel-network-list value easyv_av_butiker_splitTunnelAcl
webvpn
username xxx password xxx encrypted privilege 15
username xxx password xxx encrypted privilege 0
username xxx attributes
vpn-group-policy easyv_av_butiker
webvpn
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map Outside_dyn_map 20 match address Outside_cryptomap_dyn_20
crypto dynamic-map Outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto map Outside_map 65535 ipsec-isakmp dynamic Outside_dyn_map
crypto map Outside_map interface Outside
isakmp enable Outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
tunnel-group easyv_av_butiker type ipsec-ra
tunnel-group easyv_av_butiker general-attributes
address-pool pool_10
default-group-policy easyv_av_butiker
tunnel-group easyv_av_butiker ipsec-attributes
pre-shared-key *
/Regards
01-25-2006 06:48 AM
To define the VPN Clients' IP address pool, perform the following tasks
Define the VPN Client's Local IP Address Pool
Reference the Local IP Address Pool to Reference IKE
Specify Gateway-initiated IKE Mode Configuration
The configuration given in the following url will give an idea to confiure VPN client.
