VPN and GLBP!!!
Jan 19th, 2006
Does any body know when the "GLBP redundancy client" will be released?
Is it possible to configure VPN(site-to-site) and GLBP in same interface in Cisco router?
Is there any special commands or setup to look for?
Both GLBP and VPN is in WAN part.
Overall Rating: 3 (1 ratings)
b.hsu Wed, 01/25/2006 - 06:49
  • Silver, 250 points or more
(router-if)#glbp group name redundancy-name
Enables IP redundancy by assigning a name to the GLBP group.
The GLBP redundancy client must be configured with the same GLBP group name so the redundancy client and the GLBP group can be connected.
examples20001 Wed, 01/25/2006 - 07:34
I didnt get. Can you please give more details.
My router commands for GLBP is below:
TestC(config-if)#glbp ?
<0-1023> Group number
TestC(config-if)#glbp 10 ?
authentication Authentication method
forwarder Forwarder configuration
ip Enable group and set virtual IP address
load-balancing Load balancing method
name Redundancy name
preempt Overthrow lower priority designated routers
priority Priority level
timers Adjust GLBP timers
weighting Gateway weighting and tracking
TestC(config-if)#glbp 10 name ?
WORD Name string
TestC(config-if)#glbp 10 name load
TestC(config-if)#
How to configure the GLBP redundancy client?
