Re: Mac Address\IP Bunding on Cisco 3560
Jan 19th, 2006
I was searching for an option on the Cisco 3560 to statically assign an ip address on a particlar host on a vlan1 as an example. Currently the 3560 is DHCP enabled.
ip dhcp excluded-address 10.x.x.x 10.x.x.x
ip dhcp pool 1
network 10.x.x.0 255.255.255.255
domain-name northamerica.corporate-domain.net
dns-server 10.x.x.x 10.x.x.x
netbios-name-server 255.66.175.255
default-router 10.x.x.1
lease 0 12
What would the command be to bind a reserved ip for a host with the mac of xxxx.xxxx.xxx.xxxx
Thanks.
-fz
Overall Rating: 4 (1 ratings)
pkhatri Thu, 01/19/2006 - 15:47
  • Purple, 4500 points or more
Try the following:
For each client requiring a specific IP address, create a pool as such:
ip dhcp pool client1
host
hardware-address xxxx.xxxx.xxxx
client-name
Note that you cannot use the same pool as the one you have already got. You need to create a different pool for the client and then again, a new pool for each client requiring this.
Pls remember to rate posts.
Paresh,
zapanta.f Thu, 01/19/2006 - 16:22
Thank you very much! Is this posted on the 3560 support docs? I was unable to find this knowledge info. I'll let you know how it works out.
-fz
pkhatri Thu, 01/19/2006 - 16:28
If you read this:
http://www.cisco.com/en/US/customer/products/hw/switches/ps5528/products_configuration_guide_chapter09186a0080509b6d.html#wp1098426
.. it referneces the 'Cisco IOS IP Configuration Guide, Release 12.2' which has info on manual bindings at:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fipr_c/ipcprt1/1cfdhcp.htm#wp1001108
Pls do remember to rate posts...
Paresh.
zapanta.f Thu, 01/19/2006 - 17:03
I just tested this with the 3560 and it does not seem sot bind the address. Thanks again.
pkhatri Thu, 01/19/2006 - 17:06
Could you post the relevant bits of the config you are using ?
Paresh.
pkhatri Thu, 01/19/2006 - 17:22
Hi again,
Do you have a web server that you can access from your router ? There is another way of doing this where you can get away without having all those DHCP pools. You can place your MAC to IP mappings in a file, stick it on a web server, and get your router to use that for address assignment.
Paresh.
zapanta.f Fri, 01/20/2006 - 19:20
here is a copy of the config for 2 clients and a the DHCP Pool.
The mac\ip bundung does not seems to work. I have tested this with a laptop's unique Identifier.
ip dhcp excluded-address 172.16.12.1 172.16.12.99
ip dhcp pool 1
network 172.16.12.0 255.255.255.0
domain-name xxxdomain.com
dns-server 172.16.12.20 172.16.12.21
netbios-name-server x.x.x.x
default-router 172.16.12.1
lease 0 12
ip dhcp pool client2
host 172.16.12.100 255.255.255.0
client-identifier 0011.4342.e9a5
client-name My LAPTOP
domain-name INEED.HELP. FIXING. MY DHCPISSUE.com
dns-server 172.16.12.21 172.16.12.34
pkhatri Fri, 01/20/2006 - 19:42
Could you try with a stripped down version which just contains the following in the pool:
Also, as I previously asked, are you able to reach a locally administered web server from your router ? We could try a different tack ?
Paresh
pkhatri Fri, 01/20/2006 - 20:26
Actually, you can use a TFTP server...
First of all, create a text file using a text editor (call it 'dhcpstatic', for instance) with the following contents (don't include the dashes):
*time* Jan 21 2005 03:52 PM
*version* 1
!IP address Type Hardware address Lease expiration
172.16.12.100 /24 1 0011.4342.e9a5 Infinite
Then do the following:
no service dhcp
ip dhcp pool pool1
lease 0 12
origin file tftp:///dhcpstatic
Then do a 'service dhcp'...
Once you have this working, we can do a further optimisation by storing the file on your switch so that you don't need to use a TFTP server...
Hope that helps - pls rate the post if it does.
Paresh
