Warning message
Flash upgrade to 3745 router
Hi, I tried to upgrade our flash on our 3745 from 32M to 64M to accomidate a new flash image. The image I tried to put on was
Platform: 3745
Feature Sets: ADVANCED ENTERPRISE SERVICES
Release: 12.3.14T5
It copied ok via xmodem and then rebooted like it should have but then got caught in a loop of booting-rebooting. The image needs 128M ram which I verified we have. Ihave attached the logs of what was going on while the router rebooted. Any ideas?
Ted
Patrick Laidlaw Mon, 01/23/2006 - 16:07
  • Gold, 750 points or more
Ted,
The first thing I would do is upload the original IOS image you were using. If the system works fine from there go an try to upload the new image again via tftp.
If it doesn't work after the new image download a differet version of your image.
Patrick
