PIX to Router VPN going down
Jan 20th, 2006
I have recently implemented a site to site dynamic to static VPN between a PIX 500 series 6.3(3), and an 871W router. The PIX is the static side, and the 871W is the dynamic side.
I am having the VPN go down every 24ish hours or so. I believe that I need to do something with DPD, but I haven't been able to find exactly what. Here's part of the config of the 871W-
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key xxxx address xxxx
crypto ipsec security-association lifetime seconds 900
crypto ipsec transform-set strong esp-3des esp-md5-hmac
crypto map xxxvpn 10 ipsec-isakmp
set peer xxxx
set transform-set strong
match address 100
bridge irb
interface FastEthernet0
no ip address
no cdp enable
interface FastEthernet1
no ip address
no cdp enable
interface FastEthernet2
no ip address
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface FastEthernet4
ip address xxxxx 255.255.255.240
ip access-group 125 in
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
crypto map xxxvpn
interface Dot11Radio0
no ip address
broadcast-key vlan 1 change 45
encryption vlan 1 key 1 size 128bit 7 xxxx transmit-key
encryption vlan 1 mode wep mandatory
ssid xxxx
vlan 1
authentication open
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
rts threshold 2312
channel 2457
station-role root
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
ip address 192.168.33.1 255.255.255.0
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 xxxxx
no ip http server
no ip http secure-server
ip nat inside source list 110 interface FastEthernet4 overload
access-list 100 remark Tag traffic to be encrypted
access-list 100 permit ip 192.168.33.0 0.0.0.255 172.28.0.0 0.0.255.255
access-list 100 permit ip 192.168.33.0 0.0.0.255 172.23.0.0 0.0.255.255
access-list 100 permit ip 192.168.33.0 0.0.0.255 172.21.0.0 0.0.255.255
access-list 100 permit ip 192.168.33.0 0.0.0.255 172.20.0.0 0.0.255.255
access-list 100 permit ip 192.168.33.0 0.0.0.255 172.22.0.0 0.0.255.255
access-list 100 permit ip 192.168.33.0 0.0.0.255 172.24.0.0 0.0.255.255
access-list 100 permit ip 192.168.33.0 0.0.0.255 172.29.0.0 0.0.255.255
access-list 100 permit ip 192.168.33.0 0.0.0.255 10.28.0.0 0.0.255.255
access-list 100 permit ip 192.168.33.0 0.0.0.255 10.254.0.0 0.0.255.255
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
access-list 110 remark Performs NAT against everything but VPN traffic
access-list 110 deny ip 192.168.33.0 0.0.0.255 10.28.0.0 0.0.255.255
access-list 110 deny ip 192.168.33.0 0.0.0.255 10.254.0.0 0.0.255.255
access-list 110 permit ip 192.168.33.0 0.0.0.255 any
access-list 125 remark Restrict access on external interface fa4
access-list 125 permit udp host xxxx any eq isakmp
access-list 125 permit udp host xxxx eq isakmp any
access-list 125 permit esp host xxxx any
access-list 125 permit icmp any any
access-list 125 permit ip xxxxx 0.0.0.255 any
access-list 125 permit ip 172.28.0.0 0.0.255.255 any
no cdp run
control-plane
bridge 1 route ip
vkapoor5 Wed, 01/25/2006 - 09:50
  • Bronze, 100 points or more
I feel this could be due to the expiration of "Security Association". If there is no user traffic for a duration longer than the SA lifetime, the SA will expire and the new SA will be formed only when there is a user traffic initiated. Look at the logs for more information on why the VPN is breaking.
You can try configuring "keepalives" between the VPN peers so that the VPN is always on and does not timeout.
"crypto isakmp keepalive 10"
