Warning message
Routing from VPN Clieant to a Tunnel Help!!!!!!!
Jan 20th, 2006
hi all
like you can see from in the attacched when i connect from a remote VPN MS client i can't go to the network 10.0.15.0 that is the network i reach trought the tunnel0.
Any suggetion?
What kind of rout to reach the network 10.0.15.0
spremkumar Mon, 01/23/2006 - 23:45
  • Red, 2250 points or more
Once you login onto the network are you able to ping 10.0.11.1 ip which is the local ethernet ?
Also are you able to ping the tunnel interface ip ? can you revert which is the other end of the tunnel where(82.189.xx.xx) its gets terminated ?
Can you add a route for the ip pool network in the remote destination towards the tunnel and chek ?
I feel that may be the only problem out here with the network.you arent having the reverse route for the ip pool configured in the remote network.
regds
