Warning message
How to use Software advisor to findo ut features supported
Jan 23rd, 2006
I tried using Software advisor to find out which version of Cat5 RSM module support Diff Sev QOS. However, I do not know Diff Sev QoS bundle into whcih features listed.
Can you help me? My customer currently running this version of IOS, c5rsm-dsv-mz.121-5a
Thank you.
Delon
Overall Rating: 4 (1 ratings)
pkhatri Mon, 01/23/2006 - 01:00
  • Purple, 4500 points or more
Hi Delon,
If you are after support for traffic classification using DSCP, then that should already be supported in the c5rsm-dsv-mz.121-5a image, since it has support for the Modular Qos CLI (MQC)...
Hope that helps - pls rate the post if it does.
Paresh.
