Newbie question about NAT on Frame relay
Answered Question
Jan 23rd, 2006
I've got a location that will be installing a Sonicwall firewall behind a Cisco 1720.
Currently there is a public IP on serial0.1 and a private IP on Fa0 with NAT enabled.
We will be turning off NAT on the Router and using the Firewall to establish NAT with the exposed public IP. Generally I want have the Cisco become a transparent device.
I'm under the assumption that all I need to do is turn off NAT on all interfaces and then change the IP on fa0 to a public IP that is in the same range as the Public IP I will be setting for the Sonicwall's WAN IP.
Any help would be greatly appreciated.
Correct Answer by pkhatri about 11 years 6 months ago
That will do it... I presume you already have a default on your 1720 that points to your serial0.1 interface ?
Also ensure that your ISP has rote pointing back at your for the public IP subnet that you will be using on the link between the firewall and the 1720.
Hope that helps - pls rate the post if it does...
Paresh.
Overall Rating: 3 (1 ratings)
Correct Answer
pkhatri Mon, 01/23/2006 - 14:02
  • Purple, 4500 points or more
Paresh.
racanelv Mon, 01/23/2006 - 14:29
This added a little bit more information to confirmation that I had received from an associate. You're help is greatly apprecieated.
