Warning message
BAT to update users
Jan 24th, 2006
It seems I cannot update users directory number with BAT 5.1(4).
When I try to make an update on that field the user's PRIMARY EXTENSION gets updated but not the TELEPHONE NUMBER field, which is the one we want to change for corporate directory.
I think it worked before our last upgrade but I am not 100% sure about that.
Thank you
vmoopeung Mon, 01/30/2006 - 11:47
  • Bronze, 100 points or more
If you are using CCM 4.1
try by changing "UserDirAccess=false" to "UserDirAccess=true" in the UMDirectoryConfiguration.ini file and restarting the IIS Admin service. Then set DirAccess=true in the DirectoryConfiguration.ini file and in the registry.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008021feae.shtml
