Dialin: Different kinds of authentication based on DNIS
Jan 24th, 2006
We use a 5350 with one ISDN-PRI.
Now we want to support following.
We want to use different DNIS-numbers and based on the called number we want to do different authentication types
Some dail-in users which call one number should be authenticated by radius
(and they should get their IP-address from a pool)
some remote-offices router should dialin
for isdn-backup and should be authenticated local (for these routers we want to use dialer-profiles with fix IP-addresses)
Is this possible by using different DNIS-numbers and when , how.
We had a similar problem where we used ressource-pools to terminate on different modem (lines) based on DNIS ?
Thanks in Advance
Hubert
