Warning message
WLSE-2.11FCS Configure Job Error message
Jan 24th, 2006
Hiya, just curious if anyone has any ideas with this problem?
I configured a job using custom commands with this config:
interface Dot11Radio0
l2-filter block-arp
The WLSE fails everytime whether this is for one radio or two. The error I get:
---Device version is not supported.
---No configuration update applied to this device.
---Please select Ignore Warnings while saving this job to force configuration updates on this device.
I select ignore to force this job but it still failed with the same error.
Any ideas? Anything would be greatly appreciated.
Thanks much!
johnd2310 Tue, 01/31/2006 - 12:03
  • Silver, 250 points or more
What image is running on your access points?
John
Maralina1 Tue, 01/31/2006 - 14:45
Hiya...
We actually have over 200 APs with versions from 12.3 up and more. I was able to get this problem resolved though per TAC. They suggested I upgrade the WLSE to 2.12 which did the trick. All is working the way it should.
thanks though!
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
