Redundant WAN cisco 1801/ADSL NAT issue
Answered Question
Jan 25th, 2006
I have configured a 1801 router with ADSL and FASTETHERNET0 as wan ports. I have added two static routes with metric 1 and 2 out over these interfaces. I have also added two NAT rules for each. All traffic is coming from 192.100.151.0/24 network. Problem is it only seems to work for the 1st NAT rule, if I pull out says ATM0/0 cable it doesnt start using the FE0/1 port. I was told this would work as redundancy, any ideas?
See extract of config I think are relvant:
ip classless
ip route 0.0.0.0 0.0.0.0 195.x.x.x 2
ip route 0.0.0.0 0.0.0.0 Dialer0 3
ip nat inside source list 1 interface FastEthernet0 overload
ip nat inside source list 2 interface Dialer0 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.100.151.0 0.0.0.255
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 192.100.151.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
Correct Answer by twojciac about 11 years 6 months ago
It's possible to use the embedded event manager and script it. I haven't used EEM yet, so I don't have any canned scripts that would work for you.
Here's info on the EEM:
http://www.ciscosystems.com/en/US/products/ps6815/products_white_paper0900aecd803a4dad.shtml
Overall Rating: 5 (2 ratings)
twojciac Wed, 01/25/2006 - 06:09
I believe this is what you're trying to do. Keep in mind, in a failure scenario, you'll need to clear the nat translations manually to fail over active translations.
ip address 195.x.x.1 255.255.255.252
ip nat outside
interface FastEthernet1
ip address 192.100.151.1 255.255.255.0
ip nat inside
ip policy route-map nexthop
interface Dialer0
ip address negotiated
ip nat outside
ip local policy route-map nexthop
ip nat inside source route-map ispA interface FastEthernet0 overload
ip nat inside source route-map ispB interface Dialer0 overload
access-list 40 remark IP Addresses that may be NAT'd
access-list 40 permit 192.168.151.0 0.255.255.255
route-map ispB permit 10
match ip address 40
match interface FastEthernet0
route-map ispA permit 10
match ip address 40
match interface Dialer0
ip route 0.0.0.0 0.0.0.0 195.x.x.2
ip route Dialer0 3
rasoftware Wed, 01/25/2006 - 08:25
that fantastic, works first time and fails over perfectly.
Is there also a way to shutdown the backup interface automatically until it is needed and the revert back once the priamry is back up? I ask because we have PIX behind the router and prefer that only the fastest priamry connection is used when possible for out IPSEC tunnels and not the backup.
rasoftware Wed, 01/25/2006 - 13:21
I think maybe it is possible to use the dialer-watch command that can be used for ISDN on the dsl interface?
aadilovic Thu, 02/09/2006 - 05:04
hi twojciac,
I did same on my router; however, didn't work. In your example there is on two places "policy route-map nexthop" which is not described. Is this cruical for this to work? can you give more explanation on this?
mheusinger Wed, 01/25/2006 - 06:30
  • Green, 3000 points or more
according your config you will use the FastEthernet0 per default, assuming you have a 195.x.x.x address there!?
You specify two default routes with administrative distance 2 and 3. The lower value is the "better" or "more trustworthy" one and should be used unless 195.x.x.x is not reachable.
Can you post the output of "show ip route" and "show ip nat translations"?
This would further help to understand what is going on.
Hope this helps! Please rate all posts.
Regards, Martin
