Warning message
DC Directory Installation Failure
Jan 25th, 2006
I'm having a problem installing a Subscriber for a CallManager 3.2(3) Publisher. When I install the Sub it does not install DC Directory. The log states that it did not install because the ConfigStatus registry key was not found. I have never had this problem before ... I do not get any errors during the installation of CallManager and it completes ok and reboots. I can then access the Admin pages and look at devices but not users (obviously because it can't find the directory). If I look in the registry in the "Directory Configuration" key instead of having similiar information to the publisher, it simply has one key which tells it where the publisher is. I have double checked my lmhosts and hosts files and they are fine. Any ideas?
Alan
[email protected]
gogasca Wed, 01/25/2006 - 08:17
  • Green, 3000 points or more
Hi Allan,
It is a fresh install of .3.2(3), or an upgrade?
The password for DC Directory Manager is not using special characters?
You may gather:
C:\dcdsrvr\log
C:\Program Files\Common Files\Cisco\Logs
If you have already tried to reinstall, you may open a TAC case with us.
