1721 crash and go into ROMMonitor mode when install a MOD1700-VPN card
Jan 26th, 2006
1721 router with 128M Dram , 32M Flash , c1700-advsecurityk9-mz.124-4.T1.bin ios file, when MOD1700-VPN inserted , the router will go into Rom Monitor mode ,
here is the message of console:
System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2003 by cisco Systems, Inc.
C1700 platform with 131072 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0xd9a57c
Self decompressing the image : ###################################################################################################################################################################################################################################### [OK]
Error : uncompressed image checksum is incorrect 0x16292627
Expected a checksum of 0xE463261F
*** System received a Software forced crash ***
signal= 0x17, code= 0x9, context= 0x8000c530
PC = 0x0, Vector = 0x0, SP = 0x0
if I remove the MOD1700-VPN card , it is ok.
Who can tell me why ? Urgent and thank you
spremkumar Fri, 01/27/2006 - 04:11
  • Red, 2250 points or more
hi
Instead of your current ios code can you try running your router with some other ios code which can support the VPN Module ?
Have you already explored this option ??
you can very well check up the reqd feature set and version set which you can install up over there..
for more info try this toold to find out the code which can fit in..
http://tools.cisco.com/Support/Fusion/FusionHome.do
regds
FXCL3725Smart Fri, 01/27/2006 - 20:03
Yes, I had try different IOS , actually , the previous IOS is 12401a with FW/IDS/ADSL/3DES/IP Plus Feature set, got crashed , so , I chance the tools and fould a Advanced security feature set IOS. but ,crashed and reload 3 times and then go into Rommonitor mode . just like the previous IOS image does.
Now , I supposed it is memory problem , can any Cisco Engineer verified it for me , cause I can't find any tools which can analized the following mesg:
"*** System received a Software forced crash ***
PC = 0x0, Vector = 0x0, SP = 0x0 "
