Warning message
v5 Features
Answered Question
Jan 26th, 2006
Can anyone tell me if v5 has increased the number of user-definable alarm channel address groups (USER-ADDRS1-5)? Or better yet if it lets you create unlimited custom named groups? Failing that, how do folks generally get around this limitation? I find it most frustrating.
Also does v5 have the ability to do event filtering on a per-port basis?
tia
Correct Answer by m-hansson about 11 years 6 months ago
Yes, you can create unlimited custom named groups of ip(-ranges).
Yes, you can filter on per-port basis.
/Mattias
Overall Rating: 3 (1 ratings)
Correct Answer
m-hansson Fri, 01/27/2006 - 08:34
/Mattias
