Warning message
Policy-Based Routing to a subnet
pkhatri Thu, 01/26/2006 - 17:45
  • Purple, 4500 points or more
If you mean that you want to configure PBR with a next-hop that is not directly attached, then the answer is yes. To do so, use the 'set ip next-hop recursive ' command. As long as the router can recursively work out where the specified next-hop address is, it will work fine.
Hope that helps - pls rate the post if it does.
Paresh
