Warning message
Phone Migration
Jan 27th, 2006
I am looking to migrate one of my remote sights from one Call Manager/Unity cluster to another. Building the appropriate CSS's and gateways is no problem. Is there an easy way to export the phones from one server and import them into the other without rebuilding each phone individually with all of the lines and settings? I know I can do that with Unity, but I dont know what my options are for Call Manager.
Can anyone provide some assistance?
Overall Rating: 5 (1 ratings)
thisisshanky Fri, 01/27/2006 - 13:03
  • Purple, 4500 points or more
You can use BAT on the remote site server (existing) and export the users to a csv file. Then you can use BAT on the new servers to import the same. To avoid confusion, i may suggest using a separate partition CSS, Device pool etc for the migrated phones, so that it will be easy for you remove them later. BAT versions differ from one version of Callmanager to another, so you may have to reformat the exported BAT file to the new server's BAT version format prior to import.
PS: Please remember to rate helpful replies.
