Warning message
PIX525 Ver.7 Active-Active Failover Sample Config
Jan 28th, 2006
Does anyone have a sample config of an Active-Active Failover firewall showing failover config as well as how the physical interfaces are configured in the contexts?
varakantam Sun, 01/29/2006 - 00:33
Following are smaple configurations for an Active/Active configuration and where they should be configured
Primary Unit System space
a) Create failover configuration
failover
failover lan unit primary
failover lan interface faillink Vlan4002
failover polltime unit msec 900 holdtime 3
failover polltime interface 5
failover replication http
failover link statelink Vlan4003
failover interface ip faillink 1.1.1.1 255.255.255.0 standby 1.1.1.2
failover interface ip statelink 2.2.2.1 255.255.255.0 standby 2.2.2.2
failover group 1
preempt 300
replication http
failover group 2
secondary
replication http
interface-policy 40%
b) Create Contexts and allocate interfaces to context and make then part of one of the 2 failover groups
context TCTX19
description context TCTX19
allocate-interface Vlan3072-Vlan3075
allocate-interface Vlan3152-Vlan3155
config-url disk:/TCTX19.cfg
join-failover-group 1
context TCTX20
description context TCTX20
allocate-interface Vlan3076-Vlan3079
allocate-interface Vlan3156-Vlan3159
config-url disk:/TCTX20.cfg
join-failover-group 2
c) Interface configuration within the contexts
interface Vlan2000
description Interface for VLAN2000
nameif DMZ1_VLAN2000
security-level 80
ip address 172.1.0.1 255.255.252.0 standby 172.1.0.2
maksure you use a standby IP in the same segment as active ip.
d) Standby unit congiuration
failover
failover lan unit secondary
That should do the magic :)
