Warning message
image distribution
Answered Question
Jan 30th, 2006
When i try to set image location (rme-admin-software mgmt) an erro occurs. "User error:Invalid data directory. Verify that the directory exists" I have set path as follows. d:/LMS2.5/CSCOpx/files/rme/repository. Any idea why rme dont allow that path.
Correct Answer by nhabib about 11 years 6 months ago
Open a DOS shell and issue the command:
net stop crmdmgtd
Once it stops, backup your current repository.properties file (add a .ori to the name):
CSCOpx\MDC\tomcat\webapps\rme\WEB-INF\classes\com\cisco\nm\rmeng\repository\common\repository.properties
Place the attached file in the same location and re-start CiscoWorks:
net start crmdmgtd
Overall Rating: 5 (1 ratings)
nhabib Mon, 01/30/2006 - 07:18
  • Red, 2250 points or more
This usually happens due to a syntax error in the following file:
ory.properties
if you'd like to attach it, I can try fixing it for you.
Correct Answer
nhabib Mon, 01/30/2006 - 10:57
net stop crmdmgtd
net start crmdmgtd
u346874_2 Tue, 01/31/2006 - 10:26
Thanks Nadim. That help. Look like RME could not change the path so it must change to that repository.properties file. Hope developer people see this and do somenthing to next update for RME.
Juha
