Warning message
DHCP request through accesspoint and router
Jan 30th, 2006
This is how our setup is like:
Laptops => Cisco 1100 AP(static IP) => Wired LAN (Subnet 1) => Cisco Router => Wired LAN (Subnet 2) => DHCP server
What i would like is that the DHCP-request from our laptops is forwarded/relayed through the AP and Router to the DHCP-server and back.
We dont want to use the AP's internal DHCP server but centralise this.
At the moment i'v configured the AP through CLI and added the following command: ip dhcp-server xx.xx.xx.xx
Where xx is the IP of the DHCP server
On the Router i'v added the command ip helper-address xx.xx.xx.xx
Don't know if this is the correct way, but i do know it isn't working.
Some help is realy appreciated.
Grx,
Joris
kka Mon, 01/30/2006 - 13:42
With your setup you don't need any DHCP configuration on the AP.
The AP works as bridge between the radio IF and the Ethernet IF,
this includes DHCP.
Just as you wrote configure "ip helper-address ..." on the router's
IF connected to Subnet 1. Make sure DHCP is enabled on the router,
("service dhcp" is default, invisible in the config).
joris_struijk Tue, 01/31/2006 - 00:41
So yust remove the "ip dhcp-server" command in the AP and setup the LAN side with a static IP (like i have done already). This should do the trick?
And on the 3600 router i have to use the "ip helper-address" command to forward the request.
But, then what is the AP's "ip dhcp-server" command good for? When should i use it?
kka Tue, 01/31/2006 - 06:42
If you are using DHCP to assign an IP address to your AP, i.e.
interface BVI 1
ip address dhcp
you can limit the DHCP servers from which the AP accepts
DHCP leases with "ip dhcp-server x.x.x.x".
joris_struijk Tue, 01/31/2006 - 06:31
Ok, i'v fixed that problem by configuring a right scope.
Next major problem that's bothering me the whole day.
The DHCP server has to be placed behind a Windows 2003 server with router functionality. This server will be promoted to an ISA server later in the project. First we have to setup the connection properly.
I'v setup the 3600 router with the approperiate "ip helper-address xx.xx.xx.xx" command. This works.
The DHCP server that's going to serve the IP-addresses is placed behind a Windows 2003 server with DHCP-relay installed.
Interface 1 of the Windows 2003 Router is connected to the Cisco router, interface 2 is connected to the subnet where the DHCP server resides. This Windows 2003 router has to forward the already forwarded DHCP request to the correct DHCP server.
That's the problem, i don't know how to let Windows 2003 correctly forward the Cisco router's DHCP request.
HELP ;)
kka Tue, 01/31/2006 - 07:33
I'm not familiar with Windows DHCP server, but I guess
it supports standard DHCP including evaluating the
giaddr field from the DHCP relay.
You only need one DHCP relay (your Cisco router).
Between the router and your DHCP server the DHCP traffic
is unicast, so you have to make sure that the routing
between the DHCP server and the router's IP (giaddr)
in your Subnet 1 works.
joris_struijk Tue, 01/31/2006 - 07:48
Are you able to present me with some tips to check that connectivity is correct? We tryied to ping the DHCP server from the router and that seemed to work.
Maby were missing something.
kka Tue, 01/31/2006 - 10:55
You need at least the following connectivity for DHCP relay to work.
Between the DHCP relay agent and the DHCP server:
- UDP Port 67 <-> UDP Port 67
Between the DHCP server and the DHCP client:
- UDP Port 67 <-> UDP Port 68 (renewing/releasing a lease)
- ICMP echo (Most DHCP servers check if an IP is still free)
On the Cisco router you can use some debugging commands
to check that relaying works.
(This might produce a lot of output, careful on a production system.)
#term mon
#debug ip dhcp server packet
#debug ip dhcp server events
For Subnet 1 with the router's IP 10.0.0.1 and two configured
DHCP servers (192.168.0.1, 192.168.9.1) as "ip helper" a successfull
exchange looks like this:
DHCPD: DHCPREQUEST received from client 0100.aabb.bbcc.cc.
DHCPD: setting giaddr to 10.0.0.1.
DHCPD: BOOTREQUEST from 0100.aabb.bbcc.cc forwarded to 192.168.0.1.
DHCPD: BOOTREQUEST from 0100.aabb.bbcc.cc forwarded to 192.168.9.1.
DHCPD: forwarding BOOTREPLY to client 00aa.bbbb.cccc.
DHCPD: Forwarding reply on numbered intf
DHCPD: creating ARP entry (10.0.0.49, 00aa.bbbb.cccc).
DHCPD: unicasting BOOTREPLY to client 00aa.bbbb.cccc (10.0.0.49).
#undebug all
I would also try to ping the router's IP in Subnet 1 and a client
with a fixed IP in Subnet 1 from the server. (The DHCP server uses
this to check if a lease is actually free before handing it out)
Otherwise it's time for packet sniffing on the DHCP server
and the client. (snoop, tcpdump, ethereal)
joris_struijk Wed, 02/01/2006 - 03:07
Were debugging right now.
We checked the routes (OK) pinging in both ways, server to client(with static IP at the moment) and back (OK)
Still our client gets no IP when set to auto
Our result is as following:
DHCPD: setting giaddr to 10.6.32.1
DHCPD: BOOTREQUEST from 0100.aabb.bbcc.cc forwarded to 10.6.0.2
And this ofcourse with the right MAC (to much typing)
Nothing comes back to the router, but we know the routes are confirured correctly.
Now what? Were stuck here.
joris_struijk Tue, 01/31/2006 - 09:37
Additional question1:
What exactly do you mean with "giaddr"? An how can i check that this is setup and routed correctly?
Additional question2:
Is it possible for routers (non Cisco, Windows) to reroute the request to other subnets (this is what we need)?
kka Tue, 01/31/2006 - 10:58
giaddr is a field in the DHCP packet. It contains the IP address
of the DHCP relay agent. In your example it's the router's IP
in Subnet 1. The DHCP server uses this to find the right
DHCP-pool and as destination address for its answers.
Not sure what exactly you mean by "reroute the request to other subnets".
But if you mean is it possible to use one DHCP server for several
subnets, the answer is yes. DHCP-pool and reply address can be
evaluated from the "giaddr" field in the DHCP packet. The rest
is simple IP routing between the DHCP server and the DHCP relay agent.
Basically you need routing for every subnet between the DHCP server and the relay.
joris_struijk Tue, 01/31/2006 - 11:16
Thx for the great responce so far.
I am at home right now, so testing is the first thing i'll be doing in the morning.
More to come tomorrow.
Grx,
Joris
joris_struijk Wed, 02/01/2006 - 04:01
joris_struijk Wed, 02/01/2006 - 04:23
Were monitoring the DHCP server right now and it recieves DHCPdiscover packets from the Cisco relaying router and nothing else. No offer, nothing. What could be the problem of this?
kka Wed, 02/01/2006 - 06:02
DHCPOFFER ist the reply from the DHCP server to the client.
The DHCP transfer works like this:
Client --DHCPDISCOVER--> DHCP relay agent --DHCPDISCOVER--> DHCP server
Client <---DHCPOFFER---- DHCP relay agent <---DHCPOFFER---- DHCP server
Client ---DHCPREQUEST--> DHCP relay agent ---DHCPREQUEST--> DHCP server
Client <----DHCPACK----- DHCP relay agent <----DHCPACK----- DHCP server
Looks like your DHCP server isn't answering the forwarded
DHCPDISCOVER from the client.
Does your DHCP server on 10.6.0.2 have a pool for the 10.6.32.0 net?
joris_struijk Wed, 02/01/2006 - 06:53
We narrowed it down to the Windows 2003 acting as router.
We temp. replaced this windows router with another cisco router and then it works.
Wen we then place back the windows router it stops working.
The windows router doesn't correctly routes the Cisco's DHCPdiscover,DHCPrequests etc...
Now what??
We must be doing something wrong on the windows router but what?
joris_struijk Wed, 02/01/2006 - 08:06
what is the meaning of "no ip directed-broadcast"?
we disabled this but to no result
joris_struijk Wed, 02/01/2006 - 23:29
I'v run Ethereal on the Windows router and it shows the following:
Broadcast from Cisco Router, Protocol ARP, Info: Who has 10.6.0.2? Tell 10.6.128.1.
Reply on interface loop from the Cisco Router.
On the other interface he gets an ARP reply from the DHCP server responding that the DHCP server is located at the 10.6.0.1 interface of the Windows router
10.6.0.2 is the IP of the DHCP server.
10.6.128.1 is the interface of the Cisco router connected to the Windows router.
Now what? The Windows ROuter isn't forwarding anything back to the Cisco router.
kka Thu, 02/02/2006 - 04:19
Why does the Cisco use ARP for an IP address (10.6.0.2) of
a subnet it's supposedly not part of? This I would expect if
the Cisco is configured with a netmask containing both IPs
10.6.128.1 and 10.6.0.2, i.e. 10.6.128.0/16
Without prefixes/netmasks it's a bit difficult to understand
your network.
Yesterday you wrote, that ping from the client to the server
(DHCP server?) works in both directions - is this for the
same setup?
joris_struijk Thu, 02/02/2006 - 01:41
I am seeing ARP requests for the 10.6.0.2 IP from the Cisco Router and nothing else. Why?
fausto-oliveira Thu, 02/02/2006 - 08:38
Are you sure that the windows router is forwarding between interfaces ?
Do "netsh routing ip relay" followed by a show global and paste the output here.
Also do "netsh routing ip dump" and paste that output.
joris_struijk Fri, 02/03/2006 - 12:39
It's working right now.
Thx for all the help, i'v learned a lot from all of you.
The windows router had a problem with one of the interface, replacing it resolved the problem.
Silly problem, difficult to trace.
Grx and all the best,
Joris
Trending Topics - Security & Network
