Warning message
Domain name filed is empty when I run the unity permission wizard
Jan 30th, 2006
I installed Domain Controller on a Win2000Advance server with Exchange 2000, I try to install Unity on another Win2000 Advance server with SQL 2000, but when I run the Unity permission wizard, the Domain name filed for create new users an groups is empty, I was unable to choose the domain, I installed everything step by step, anybody know what is the problem? thx
Overall Rating: 3.5 (2 ratings)
Hin Lee Mon, 01/30/2006 - 21:55
  • Cisco Employee,
Are you logged on to the unity server as a domain admin? Are there any netlogon errors in the windows system event logs>
Ginger Dillon Tue, 01/31/2006 - 07:41
  • Blue, 1500 points or more
Hi -
I would also check to make sure the Domain Controller is also a Global Catalog server. We have previously encountered problems when running the Permissions Wizard if the DC was also not a GC.
Ginger
elvinliang Tue, 01/31/2006 - 11:57
Thanks gkavan and hinho, I check everything again and found the problem is the DNS. I pointed all these two servers to another DNS server. :) So it can not find the Domain. I changed it back to DC, now is ok.
