Warning message
Return code: no resource (47) ; CCM 3.3(4); IP2IP 3825
Jan 31st, 2006
Plan:
ipPhone_7940/60 -- CCM 3.3(4) -- 3825(ip2ip_gateway) -- AS5350 -- PSTN
2611:
jk9s2-mz.123-12.bin
3825:
c3825-adventerprisek9_ivs-mz.124-3b.bin
After change Cisco IPIP gateway 2611 to 3825 doesn't calls from ipPhone to PSTN
CCM 3.3(4) looks at 3825 as on h.323 gateway
Configurations doesn't change from 2611 to 3825
dial-peer voice 1000 voip
description <-- To PSTN -->
destination-pattern 7[04]732......
translate-outgoing calling 15
session target ipv4:x.x.x.x
tech-prefix 22#
dtmf-relay h245-alphanumeric
fax protocol t38 ls-redundancy 5 hs-redundancy 2 fallback pass-through g711alaw
no vad
dial-peer voice 555 voip
answer-address T
fax protocol t38 ls-redundancy 5 hs-redundancy 2 fallback cisco
ip qos dscp cs5 media
no vad
voice service voip
h323
emptycapability
ip circuit max-calls 1000
ip circuit default only
