Warning message
RTP command
Jan 31st, 2006
Can someone explain me how does the comman: voice rtp send-rcv works???
That is the issue:
1. I´m unsing CCM for VoIP services in one side.
2. The transport that I´m using is a cisco 800 (A p2P circuit trough DSL).
If I use the voice rtp comman in the Cisco 800, will this help to warranty that I will not have problems like one way audio, etc.
Thanks and regards....
Overall Rating: 3 (1 ratings)
dgahm Wed, 02/01/2006 - 15:51
  • Blue, 1500 points or more
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a008009484b.shtml
The voice path is established in the backward direction at the start of the RTP stream. The forward audio path is not cut through until the Cisco IOS gateway receives a Connect message from the remote end.
In some cases, it is necessary to establish a two-way audio path as soon as the RTP channel is opened, which is before the Connect message is received. In order to achieve this, issue the voice rtp send-recv global configuration command.
Please rate this post if it is helpful.
