01-31-2006 12:19 PM - edited 03-10-2019 02:27 PM
Is it possible to log a telnet connection even if the user does not try to enter a username&password? Right now I only get a log entry if they try to log in, but I really do need to know if a connection is made. Thanks for your help.
Michael
02-01-2006 12:54 AM
I feel you can try out 2 of the commands namesly login on-failure , login on-success with keyword which will help u out in getting the login details.
do refer this link for more info on the same..
http://www.cisco.com/en/US/products/ps6642/products_white_paper09186a00801d1cb3.shtml
regds
Log in to Community
