Warning message
VPN client and 501
Jan 31st, 2006
OK I give up! Help
My vpn client 4.0.5 is not connect to the network. I'm using ISA and radius to authenticate. However client is not connecting. So the setup is ISP---Pix---ISA/Exchange/file server (windows 2000)
Here is the 501 config.
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxx
passwd xxxx
hostname pixfirewall
domain-name hshd.loc
clock timezone CST -6
clock summer-time CDT recurring
fixup protocol http 80
fixup protocol smtp 25
fixup protocol ftp 21
no fixup protocol h323 h225 1720
no fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
no fixup protocol sip 5060
no fixup protocol skinny 2000
no fixup protocol sqlnet 1521
names
access-list outbound permit ip any 192.168.101.192 255.255.255.248
access-list outside_cryptomap_dyn_20 permit ip any 192.168.101.192 255.255.255.248
pager lines 24
logging on
logging timestamp
logging trap errors
logging host inside 192.168.101.125
interface ethernet0 10baset
interface ethernet1 10full
icmp permit any echo inside
mtu outside 1500
mtu inside 1500
ip address outside 69.x.x.x.x.255.248
ip address inside 192.168.101.1 255.255.0.0
multicast interface outside
multicast interface inside
ip audit info action alarm
ip audit attack action alarm
ip local pool hshd 192.168.101.193-192.168.101.197
pdm location 192.168.101.125 255.255.255.255 inside
pdm logging errors 100
pdm history enable
arp timeout 14400
global (outside) 1 69.53.120.26
nat (inside) 0 access-list outbound
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
conduit permit icmp any any
route outside 0.0.0.0 0.x.x.x.x.120.27 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip
0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server RADIUS protocol radius
aaa-server RADIUS (inside) host 192.168.101.125 XXXXXXX timeout 10
ntp server 192.168.101.125 source inside
http server enable
http 192.168.101.125 255.255.255.255 inside
no snmp-server location
no snmp-server contact
no snmp-server enable traps
tftp-server inside 192.168.101.125 \ciscosystems\pix
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map client authentication inside
crypto map outside_map interface outside
isakmp enable outside
isakmp identity address
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup HSHD address-pool hshd
vpngroup HSHD dns-server 192.168.101.125
vpngroup HSHD default-domain hshd.hom
vpngroup HSHD idle-time 1800
vpngroup HSHD password ********
telnet 192.168.101.125 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
terminal width 80
Any help or thoughts would be welcome. Concerns is that network subnet may not proper for nat .192-.224
Bill
Patrick Laidlaw Thu, 02/02/2006 - 17:55
  • Gold, 750 points or more
Bill,
First off What is the actual problem is it the client isn't connecting or is there a problem with authentication.
Here are the steps I would take to troubleshoot your problems.
First change your Authentication to using local user accounts on your PIX temporarily or set it up to fallback to the pix for authentication. Then create an identical user account on the pix with a different password try to login using the first password on your server if no go then try using the second password. If it connects then you know your vpn setup is right just your aaa is haveing a problem.
config example:
crypto map outside_map client authentication inside local
aaa-server LOCAL protocol local
username someone password somewhere
PS, Turn you logging setting in your vpn client to high for isakmp ipsec to discovery problems with your actual vpn configuration.
Hth
Patrick
mheusinger Fri, 02/03/2006 - 02:03
  • Green, 3000 points or more
it will be worth to look at the explanations and configurations given in: "Configuring IPSec Between Two PIXes With VPN Client 4.x Access"
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00800948b8.shtml
Just skip the commented configuration part for PIX-to-PIX communication. Another document which can help you is: "How to Configure the Cisco VPN Client to PIX with AES" found at
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_configuration_example09186a00801e71c0.shtml
For troubleshooting purposes have a look at:
"Resolving Microsoft Routing Problems on Cisco VPN Clients"
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_tech_note09186a00801b7615.shtml
and
"Troubleshooting Microsoft Network Neighborhood After Establishing a VPN Tunnel With the Cisco VPN Client" at
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_tech_note09186a0080194b4a.shtml
Hope this helps! Please rate all posts.
Regards, Martin
