ip ftp username command fails
Feb 1st, 2006
I am trying to set up the default ftp username and password but get the following error. Can't see any reason for it and checked the manuals.
mensa# config t
Enter configuration commands, one per line. End with CNTL/Z.
mensa(config)# ip ftp username cisco
% invalid command detected at '^' marker.
Same happens for the password
when I check the options I have for ip
mensa(config)# ip ?
access-list Configure ip access list
default-gateway Configure ip default gateway
default-network Configure ip default network
domain-list Add additional domain names
domain-lookup Enable/Disable DNS
domain-name Specify default domain name
name-server Specify nameserver address
route Configure static routing
routing Enable ip routing
tcp Enable ip tcp path-mtu-discovery
Is there something else I have to do first ?
Any help much appreciated
Overall Rating: 3.5 (2 ratings)
pkhatri Wed, 02/01/2006 - 02:27
  • Purple, 4500 points or more
Hi Gordon,
What platform and software version is this for ?
Paresh
gstonian1 Wed, 02/01/2006 - 03:09
Hi, this is for the MDS9120
mensa# show version
Cisco Storage Area Networking Operating System (SAN-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2005, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
BIOS: version 1.1.0
loader: version 1.2(2)
kickstart: version 2.1(2b)
system: version 2.1(2b)
BIOS compile time: 10/24/03
kickstart image file is: bootflash:/m9100-s1ek9-kickstart-mz.2.1.2b.bin
kickstart compile time: 8/30/2005 19:00:00 [09/18/2005 19:47:18]
system image file is: bootflash:/m9100-s1ek9-mz.2.1.2b.bin
system compile time: 8/30/2005 19:00:00 [09/18/2005 20:07:26]
Hardware
cisco MDS 9100 ("1/2 Gbps FC/Supervisor")
Intel(R) Pentium(R) III CPU - with 964000 kB of memory.
Processor Board ID JAB093400VV
bootflash: 500736 blocks (block size 512b)
slot0: 0 blocks (block size 512b)
mensa kernel uptime is 48 days 21 hours 52 minute(s) 47 second(s)
Last reset at 460859 usecs after Wed Dec 14 15:22:16 2005
Reason: Reset Requested by CLI command reload
System version: 2.1(2b)
Service:
Hope this is enough info.
Gordon
pkhatri Wed, 02/01/2006 - 15:14
Hey Gordon,
Unfortunately, the 'ip ftp username|password' commands are not supported on any of the software releases for the MDS9120 yet.
Paresh.
