ROUTER 2801 WITH 4FXS/DID-HOW TO CONFIGURE?
Feb 1st, 2006
We currently have a brand new router at our office that will be used in conjunction with CallManager 3.3 to integrate GSM cellular telephony in our data network. I'm looking for a configuration example to configure the router.
this is the way we have the equipment installed:
<cellular network>----(Licea-GSM SIM CARD equipment)-->FXS(ROUTER)--(IP CAMPUS NETWORK)
The router show version is as follows:
R_VOICE_GSM#sh ver
Cisco IOS Software, 2801 Software (C2801-IPVOICE-M), Version 12.3(14)T6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 04-Jan-06 21:38 by dchih
ROM: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
ROM: Cisco IOS Software, 2801 Software (C2801-IPVOICE-M), Version 12.4(5), RELEASE SOFTWARE (fc3)
R_VOICE_GSM uptime is 1 minute
System image file is "flash:c2801-ipvoice-mz.123-14.T6.bin"
Cisco 2801 (revision 5.0) with 116736K/14336K bytes of memory.
Processor board ID FTX0949D1UU
2 FastEthernet interfaces
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
4 Voice FXS interfaces (VIC 4FXS/DID)
I had some problems with the configuration because when I put:
#sh voice port
there is no results. Maybe because the 4Fxs/did Card hasnt been recognized by the router.
I have tried upgrading the 2801 with the follow IOS:
But I had the same results.
What do I have to dO?
Can you help me with some configuration?
Thanks in advanced.
Walter Munguia
UNMSM - Lima -PERU
thisisshanky Wed, 02/01/2006 - 13:35
  • Purple, 4500 points or more
Do you see the port (voice-port x/y) on the running config ?
Also paste a sh voice port summary. Since it shows up on the sh version, i assume you have DSP chips installed on the router. Does the GSM SIM card equipment expect dial tone from the router ?
wmunguiam Mon, 02/06/2006 - 07:29
Thisisshanky,
Thanks for your reply.
I found something obvious: there is no response when I put SH RUNN.
IT IS BECAUSE THE ROUTER DOESNT HAVE A PDVM MODULE INSTALLED.
here is teh sh ver:
GW_UNMSM#sh ver
Cisco IOS Software, 3600 Software (C3640-IS-M), Version 12.3(11)T5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Sat 02-Apr-05 12:23 by yiyan
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
GW_UNMSM uptime is 1 day, 20 hours, 21 minutes
System returned to ROM by reload
System image file is "flash:c3640-is-mz.123-11.T5.bin"
Cisco 3640 (R4700) processor (revision 0x00) with 89088K/9216K bytes of memory.
Processor board ID 26856110
R4700 CPU at 100MHz, Implementation 33, Rev 1.0
62 Serial interfaces
2 Channelized E1/PRI ports
125K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
GW_UNMSM#
so I have to buy one module.
heathrw Sun, 02/12/2006 - 17:02
  • Bronze, 100 points or more
try a 'show dsp all'
wmunguiam Fri, 02/24/2006 - 14:23
ok...
NOw I have a DSP and FXO modules installed in the ISR 2801.
So I have to continue testing configuration to find out the solution!
