02-01-2006 02:08 PM - edited 03-03-2019 11:37 AM
Allright, let me see if I can explain myself here:
I have a Cisco 831 router runnning 12.3 code. On the public interface "ethernet1" (which, incidently, goes to an aDSL modem to the internet), I'm running a GRE tunnel with GRE keepalive (actually it's GRE over IPSec, if it pertains to the question) that I'm learning routes through EIGRP into our main office. The ethernet1 interface itself, however, is a passive interface for EIGRP; I just have a statically configured default route for internet bound traffic. I am also redistributing this static default route using EIGRP to other routers on the segment on the inside network "ethernet0".
So far, so good.
Here's the delima:
If, for some reason, the DSL connection dies on the public side, the tunnel interface will go down and the EIGRP process will make the approrpriate changes to the inside routes, however, since the default route is statically defined and the ethernet1 interface never actually goes down, my router will continue to advertise the redistributed default route to the inside network.
My question is this:
Is there any way to force the router to stop adverising the default route when the DSL line dies? For instance, is there a way to force the entire ethernet1 interface down if the GRE tunnel interface that's running over it goes down?
Please let me know if I need to clarify anything, and thanks in advance for any responses.
Solved! Go to Solution.
02-02-2006 06:37 PM
Here's a sample config with the new syntax:
Replace
interface Ethernet 0
ip address 10.1.1.1 255.0.0.0
ip sla monitor 1
type echo protocol ipIcmpEcho
timeout 1000
frequency 3
threshold 2
ip sla monitor schedule 1 life forever start-time now
track 100 rtr 1 reachability
access list 101 permit icmp any host
route-map LOCAL_POLICY permit 10
match ip address 101
set ip next-hop
set interface null0
ip local policy route-map LOCAL_POLICY
ip route 0.0.0.0 0.0.0.0
Hope that helps - pls rate the post if it does.
Paresh
02-01-2006 02:40 PM
Howdy,
What you need is reliable static routing using object tracking. Here's a link to the feature documentation:
Reliable Static Routing Backup Using Object Tracking:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5413/products_feature_guide09186a00801d862d.html
With this feature, I suggest you set up a tracking object that tracks the status of an RTR (SAA) object. Set up the RTR object to ping some reliable address on the Internet, preferably the WAN-side IP address of your ISPs' link to you. When the ping starts to fail, the tracked object status will go down, bringing down your static route.
The only gotcha with this is that it requires at least 12.3(8)T on the 831 with the IP/FW 3DES or IP/FW/PLUS 3DES feature sets. But it should resolve your issue if you are willing to upgrade...
Paresh.
02-02-2006 08:12 AM
Thanks, I wasn't aware of this feature and seems to be something that could be useful. . .
however, I'm running version 12.3(14)T6 with the IP/FW/PLUS 3DES feature set, but the "rtr" commands don't seem to be available.
Are you sure this feature is available for the 800 series routers? The documentation you referred to makes note that it is supported on the 1700 series model, but makes no mention of the 800 series . . .
02-02-2006 12:02 PM
That feature is available for the 831 but Cisco has changed that feature name from 'Service Assurance Agent' to 'IP SLAs'. And guess what the first IOS where this happened was ? 12.3(14)T...:-)
Anyway, the feature is still there.. the commands now start with 'ip sla' instead of 'rtr'. The following doc has info on how to configure the rtr bits using the new syntax:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hsla_c/hsicmp.htm
Paresh
02-02-2006 06:37 PM
Replace
ip sla monitor 1
timeout 1000
frequency 3
threshold 2
set ip next-hop
set interface null0
Paresh
