Warning message
virus access-list help
Answered Question
Feb 2nd, 2006
Hello all,
I have an access-list that is denying any access to eq 445. Someone had set this list up before I was here, and I assume it's for some Blaster varient or something.
The problem is one of the System guys says it's a legit service, something to do with Active Directory.
When I do "sh logging" I see thousands of hits where it deny's one packet at a time from port 445 to misc IP addresses.
I do "sh access-list" and the deny 445 entry has millions of hits.
We do a network wide Symantec update and scan and find nothing.
Should I disable this 445 entry? Is it a legit service?
Thanx for any help
Correct Answer by Patrick Laidlaw about 11 years 6 months ago
Port 445 is SMB over tcp or commonly referred to now by Microsoft a CIFS (Common Internet File System). This is vallid traffic so internally between sites that transfer files you should not be blocking this traffic but from external nets by all means this should be blocked.
HTH please rate any posts that were helpful.
Patrick Laidlaw
Overall Rating: 5 (2 ratings)
Correct Answer
Patrick Laidlaw Thu, 02/02/2006 - 09:29
  • Gold, 750 points or more
Patrick Laidlaw
nethelper Thu, 02/02/2006 - 10:01
  • Silver, 250 points or more
this port was meant to be blocked with regard to the W.32 Blaster Worm. The entire access list needs to be like the one below, and be applied inbound and outbound on the externally facing interface:
-->block TFTP
access-list 115 deny udp any any eq 69
-->block W32.Blaster related protocols
access-list 115 deny tcp any any eq 135
access-list 115 deny udp any any eq 135
-->block other vulnerable MS protocols
access-list 115 deny udp any any eq 137
access-list 115 deny udp any any eq 138
access-list 115 deny tcp any any eq 139
access-list 115 deny udp any any eq 139
access-list 115 deny tcp any any eq 445
access-list 115 deny tcp any any eq 593
-->block remote access due to W32.Blaster
access-list 115 deny tcp any any eq 4444
-->Allow all other traffic
access-list 115 permit ip any any
interface
description external interface
ip access-group 115 in
ip access-group 115 out
Check the Security notice for the W.32 Blaster:
Cisco Security Notice: Cisco Security Notice: W32.BLASTER Worm Mitigation Recommendations
http://www.cisco.com/warp/public/707/cisco-sn-20030814-blaster.pdf
Nethelper
