Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1926385members
1238180discussions
Community Activity
The 'vlan database' command is not working on the 2690-24TT switch
Hello everyone,I am a teaching assistant at an university. I'm using Packet Tracer to configure VLANs based on MAC addresses, but when I try to use the 'vlan database' command, I encounter the following error:Switch#vlan database^ % Invalid input det...
nvertee by Level 1
  • 184 Views
  • 7 replies
DNA 2.3.7.3 Install error on exsi host
I am installing DNA Center 2.3.7.3 on an exsi host.  The install fails with the following message.Traceback (most recent call last):File "/usr/local/lib/python3.6/dist-packages/maglev_config_wizard/commands/silent.py", line 173, in cliexit_with_error...
9800 Guest Anchor Design
I am trying to understand Guest Anchoring with the 9800 Controllers. In the 5500 series WLCs you had to access the WMI from the inside network through the firewall to the Anchor Controller Mgmt Vlan on a DMZ.  Then create another sub-interface on the...
nx-os EoL 9.3.x
Hello All, Question in Nexus 9.x    We have an EoL notice for version 9.3x.  There's no replacement available at this time.   Can we assume that a version 9.4 version will be released?   I don't see any EoL for 9.x at this time.  The customer doesn't...
IE3400 Heavy Duty Series Uplink Network Configuration
I have a new project that we are considering to use IE3400 Heavy Duty series switches to support the remote field sites. I have few design questions:Our network architecture includes a main hub site with core switches (standard Cat-9500 stack) and 22...
ezisaac by Level 1
  • 94 Views
  • 2 replies
Cisco 9300X Static routes don't work to SVI Tunnels
NOTE: I have done the same test setup with 4000 series routers, and routing works fine.I have successfully setup 3 SVI (Static Virtual Interface) tunnels with IPSEC between 2 9300X switches.- I can ping the tunnel IPs- I can ping each VLAN interface ...
Secure Client ISE 3.2 Posture failure
I have just started using Secure Client Posture on my windows workstations.  All but 2 work fine.  The two are using the IP of the ISE instead of the FQDN.  All systems have the same ISEPostureCFG.xml files on them. If I disable the network connectio...
Only one IPv6 link local unicast address is possible per interface?
Hi, members! 1. I met the following sentence. Is it true or false ?     " Only one IPv6 link local unicast address is possible per interface " 2. Can some Cisco devices have the secondary IPv6 link local address on an interface ?   I already read the...
ekc by Level 1
  • 78 Views
  • 1 replies
