Using an IPAQ as a phone
Feb 3rd, 2006
I swear that a few years ago we set up an Ipaq on CallManager and was able to use it as a wireless IP phone. We had CCM 3.1, and I don't remember needing any special phone emulation software. Is anybody familiar with this setup? We now have CCM 4.01a(sr2)and I cannot remember how this was done. I have not been able to find any instructions, either. Thanks...
Overall Rating: 3 (1 ratings)
mheusinger Wed, 02/08/2006 - 06:24
  • Green, 3000 points or more
as the CCM is handling signaling for VoIP, the first question is, which signalling protocolls do you use?
Based on the answer I would look for an IP soft phone application and then ... RTFM ;-)
One Softphone which I have heard should work is "IP Blue VTGO!", which I was told even was bundled on the companion CD of the IPAQ.
Maybe you can check this and work from there.
A little Search revealed this on IP Blue and Call Manager interoperation:
www.cisco.com/global/DK/docs/presentations/ IP_Blue_Cisco_Innovation_Day_May_2004.pdf
So this is what I would opt for. Seems to be a working solution without too much hassle involved.
Hope this helps! Please rate all posts.
Regards, Martin
vanamen Thu, 02/09/2006 - 16:12
Thanks for the direction. I hadn't heard RTFM in a while. ;-)
