Warning message
Understanding the Router product line
Feb 6th, 2006
I'm in the process of doing a comparison between the newer 2800 (2811 to be exact) vs. a 3725. I am finding (or atleast it appears) that it is apples to oranges. I noticed that I can find things like "packets per second" for the 3725, but the 2800 series talks about lots of slots and abilities for things like VoIP. Can someone help me to understand the difference between what they are calling an Access Router (3725 etc) and a Multi-Service Router (2800 etc..)? I consult for a wireless ISP and which has currently a 45Mbps 802.11A backbone. Right now is is a switched backbone with 2611XM's doing InterVLAN routing. We are moving to a routed network and feel we need to upgrade the routers.
Overall Rating: 5 (1 ratings)
Marvin Rhoads Tue, 02/07/2006 - 05:51
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
Have you looked at the Cisco Product Quick Reference Guide (QRG)? The QRG is a good place to start for comparison of the various products and product lines. See http://www.cisco.com/warp/public/752/qrg/ for access.
Generally the 2811 would be good for a T-1 or two on the WAN side and the 3725 can accommodate higher speed WAN interfaces along with higher density port cards.
The 3725 will generally have more CPU horsepower but the AIM modules available on the 2800 series may offset that advantage depnding on what services you see your environment needing to use.
The 3700 series is also more expandable via a wider selection of interface cards.
Hope this helps - please rate the post if it does.
ge4sat Wed, 02/08/2006 - 09:37
Yup, I registered to be notified when the February QRG was released. I went to Amamzon to try and get the older one, but it cant be found. Do you have any idea where I can find the July one until the February edition is published?
Thanks Again
ge4sat Wed, 02/08/2006 - 12:45
Ok, I sent the email. Thanks again for all your help.
