Warning message
QRT not working
Feb 6th, 2006
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
I configured QRT but everytime I press
the softkey nothing happens and I get:
Error: kCtiDeviceOpenFailure - Device Open failed
CTI Connection Id: 6
Device Name: SEP001647E1D0C1
UNKNOWN_PARAMTYPE:ReasonCode: 2362179744
App ID: Cisco CTIManager
Cluster ID: CGCCluster
Node ID: 10.50.140.21
CTI Application ID: Quality Report Tool
Process ID: 1300
Process Name: CtiHandler
Explanation: Application is unable to open the device
Recommended Action: Check the reason code and correct the problem.
I have not restarted the CTI service because it is in production right now. I'll try it later. Is there anything else I should be trying?
Chris
gogasca Mon, 02/06/2006 - 16:59
  • Green, 3000 points or more
Hi Chris is CEF enabled in all servers in the cluster?
Only recap an Internal DDTS (U) in which Callback and QRT do not work on Phones registered to secondary CCM
The problem was because CTI Manager tried to open a device on a wrong node.
Let us know if Restarting CTI help.
Chris Deren Tue, 02/07/2006 - 05:04
  • Hall of Fame,
As I susspoected restarting te CTIManager service did the trick.
Chris
