SIP: Inbound/Outbound Calls
knmezi
Hi Guys:
Please I need help with this problem, whenever I make a call from my gateway, instead of the call going out thru the outbound route it will go thru the inbound and this call will not complete.
See debug below:
*Apr 17 20:45:41.636: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 71.16.179.175:5060
*Apr 17 20:45:41.636: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Apr 17 20:45:41.640: //287/A3C4B0D1BA6A/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x6564FA34
*Apr 17 20:45:41.640: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 67.103.156.147:5060;branch=z9hG4bK21365
From: <sip:7032296785@67.103.156.147>;tag=6A1E1DC-293
To: <sip:71.16.179.175>;tag=85D63064-333
Date: Tue, 07 Feb 2006 00:29:49 GMT
Call-ID: A3C5E921-96A711DA-A00ED1BC-A584C9CA@71.16.179.175
Server: Cisco-SIPGateway/IOS-12.x
Timestamp: 1019076341
Content-Length: 0
CSeq: 101 BYE
*Apr 17 20:45:41.640: //287/A3C4B0D1BA6A/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 4070 DiscTime:11129043 ConnTime 11127294
*Apr 17 20:45:41.644: //287/A3C4B0D1BA6A/SIP/State/sipSPIChangeState: 0x6564FA34 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DEAD, SUBSTATE_NONE)
*Apr 17 20:45:41.644: //287/A3C4B0D1BA6A/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x6564FA34
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number :
Called Number : 7032296785
Source IP Address (Sig ): 67.103.156.147
Destn SIP Req Addr:Port : 71.16.179.175:5060
Destn SIP Resp Addr:Port : 71.16.179.175:49290
Destination Name : 71.16.179.175
*Apr 17 20:45:41.644: //287/A3C4B0D1BA6A/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : g729r8
Negotiated Codec Bytes : 20
Negotiated Dtmf-relay : 6
Dtmf-relay Payload : 101
Source IP Address (Media): 67.103.156.147
Source IP Port (Media): 18632
Destn IP Address (Media): 71.16.179.175
Destn IP Port (Media): 18494
Orig Destn IP Address:Port (Media): 71.16.179.175:18494
Disconnect Cause (CC) : 16
Disconnect Cause (SIP) : 200
teodorgeorgiev
Level 4
Level 4
Dude, I have seen previous posts of yours. You never value other's people replies/help. So, count me as one of the persons that would never reply to you :)
If you are too lazy to value the help of these people here on the forum, go outside and pay to consulting companies for support. That's the way.
Hi, if you give me a solution that solve the problem I always rate the person to 5.
