Warning message
agensler Tue, 02/07/2006 - 04:45
  • Cisco Employee,
Not possible, sorry. CME phones will always use G711ulaw when calling amongst other CME phones. CME phones can do G729 if calling out an H.323 / SIP dial-peer configured for G729.
omendieta77 Tue, 02/07/2006 - 06:40
Totally agree.
It doesn't make sense to use g729 in the LAN, you will not save enough bandwidth taking advantage that you are using Switches that support QoS, and 10/100 Mbps interfaces.
Orlando.
ELIAS AGGELIDIS Tue, 02/07/2006 - 08:46
Thanks for the reply,
but if you use CME over the WAN it makes sense to use G729a
(CCM does it)
E
