How to configure router in bridge mode
Answered Question
Feb 8th, 2006
I have 2 cisco 2621 series routers to be configured in bridge mode.
i'll be connecting this 2 routers using serial connection 128 lease line.
the problem is im not sure how to configure this 2 routers in bridge mode.
as far as i know, i need to issue the command no ip routing.
is there anything else i need to do?
can anyone guide me on how to configure
the router in bridge mode? is there any support page for this is cisco website?
thanks
Jega
Correct Answer by lgijssel about 11 years 4 months ago
Please check the link to the configuration guide below. It describes how to configure transparent bridging.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a00800ca65a.html
Leo
Overall Rating: 4 (1 ratings)
CSCO10587322 Wed, 02/08/2006 - 17:48
Hi Friend
Thank you so much for your immediate reply.
I managed to find some clear guide on configuring routers in bridge mode. really appreciate your help
your solution did helped me.
Jega
