Warning message
Configuring an IPSec Tunnel Between Router and PIX w/Duplicate LAN Subnets
Feb 8th, 2006
As in title,
I need to make a site to site vpn between an pix and a router with duplicated subnets.
Pix as inside have a 192.168.144.0/24 and he manages already 2 site-to-site vpn, one with another pix (that have inside 10.10.9.0/24) and the second one with another pix (that have inside 10.10.12.0/24). Now i need to add another one vpn site to site with cisco ios (that have "inside" 10.10.9.0/24).
Any sugestion, egsample or link?
mheusinger Wed, 02/08/2006 - 06:01
  • Green, 3000 points or more
what you need to do is to perform NAT before the IPSec tunnel and translate the second 10.10.9.0/24 to some other network not yet used on the PIX, f.e. 10.10.99.0/24. The NAT configuration on the router would look like this:
crypto isakmp policy 10
hash md5
authentication pre-share
group 2
lifetime 300
crypto isakmp key MyKey address 2.2.2.2
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto map mymap local-address Serial0/0
crypto map mymap 10 ipsec-isakmp
set peer 2.2.2.2
set security-association lifetime seconds 180
set transform-set myset
match address 110
interface Ethernet0/0
ip address 10.10.9.1 255.255.255.0
ip nat inside
interface Serial0/0
ip address 1.1.1.1 255.255.255.252
crypto map mymap
ip nat outside
ip nat pool NATforTunnel 10.10.99.1 10.10.99.254 netmask 255.255.255.0
ip nat inside source list 110 pool NATforTunnel
access-list 110 remark NAT-list
access-list 110 permit ip 10.10.99.0 0.0.0.255 192.168.144.0 0.0.0.255
Extend the ACL 110 to your needs and adjust the IPSec stuff and IP addresses to your environment.
Hope this helps! Please rate all posts.
Regards, Martin
UNIKAPERUGIA Wed, 02/08/2006 - 07:33
Perfect, can you make me an eesample on the pix side?
Thanks ;)
Ranbeckycr_2 Tue, 05/24/2011 - 08:46
mheusinger
Thanks for this post, quick question, this example is to configure the router on my location, NOT the remote location right?
