CME-to-CME with h323 gw + gk
Feb 8th, 2006
Hi there :)
I'm trying to connect two CME routers, 2811 with 124T release, to eachother with h323 gateway and gatekeeper config.
1 router is acting as gw and gk, and the other is only configured as gw.
I have tried al kinds of tip's i found on this forum, but no luck whatsoever.
Call's made from fxs ports from gw router to fxs port on gw/gk router work fine, but from ephone to ephone it will not :(.
little sketch: ipphone >> router >> lan >>router>> ipphone.
Would anyone be so kind to post the gatekeeper / gateway parts of a working config with ephone's?.. My config is below, Kind regards MJ.
Gateway router:
interface FastEthernet0/1
ip address 192.168.4.20 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip id zaak ipaddr 10.10.10.1 1719
h323-gateway voip h323-id gwzaak
h323-gateway voip bind srcaddr 192.168.4.20
GW + GK router
ip address 192.168.4.10 255.255.255.0
duplex auto
speed auto
h323-gateway voip id roel ipaddr 10.10.10.1 1719
h323-gateway voip h323-id gwroel
h323-gateway voip bind srcaddr 192.168.4.10
gatekeeper
zone local roel hollander.local
zone local zaak hollander.local
zone prefix zaak 12*
zone prefix roel 13*
rrq dynamic-prefixes-accept
no shutdown
Overall Rating: 4 (1 ratings)
ebreniz Tue, 02/14/2006 - 08:37
  • Silver, 250 points or more
e-phone dns no longer register with H323 gatekeeper
Will register if there is a dialplan configured as well as a secondary number under ephone dn.
In this two configuration steps are required
a. Under the ephone-dn, configure a "secondary" number
b. Under telephony-service, configure a dialplan-pattern.
Your running into a bug CSCsb39861
