config port security on 3548s
Feb 8th, 2006
I am wondering if there is an easier way for me to set port security on multiple ports at once than one at a time with 3548s. I know with 3550 you can use the "interface range" command to accomplish this from config mode.
I tried using the CNA which allows you to highlight multiple ports but there's a problem setting meximum address count over 1. I'm trying to limit them to 2 but it won't let me save if I choose any number higher than 1. However doing it fomr command line works...
