Warning message
static ip on vpn connection?
Feb 8th, 2006
Using an ASA5520 device, I have setup VPN on that device. It doles out IP addresses from a pool. There is 1 PC that will VPN into the network and I need to have that PC have the same IP address every time. Is there a way to DHCPC to clients, yet have a static IP on 1 client (reservation of an IP Address)
Patrick Laidlaw Thu, 02/09/2006 - 22:54
  • Gold, 750 points or more
You could create two vpn groups one for the static user makeing a vpn dhcp pool with only one ip address in it. The other vpn group would then be able to be used by the rest of your vpn users and set it up with a seperate vpn dhcp pool.
Patrick
HTH please rate any posts that were useful.
