UnityDB - Schema
Feb 8th, 2006
  • Blue, 1500 points or more
Is there a doc out there describes each field in the UnityDB tables?
More specifically, I am wondering what the "pwtimelasthack" column is in the Subscriber table.
mapennin Thu, 02/09/2006 - 08:23
  • Cisco Employee,
Hello - that particular field is the date/time of the last invalid password attempt.
As for a doc - I highly recommend using CUDLE which allows you to browse the database *and* has column level documentation for many of the column.
If it's not installed on your particular version of Unity you can download it here:
http://www.ciscounitytools.com/App_CUDLE.htm
- Matt
