Warning message
Customer 1400 Power injector stolen
Feb 9th, 2006
I have a customer with a 1400 link that had the indoor power injector and power supply stolen.
I am ordering the AIR-PWRINJ-BLR1=. Does this come with both the power injector and power supply?
If it doesn't come with the power supply what can I order that will work with the power injector?
Rob Huffman Fri, 02/10/2006 - 07:22
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey RaveDave,
That is a great question! We do not use the 1400's, so I tried to find this info on the Cisco site (good luck!!).I think you should order the following part:
AIR-PWR1400=
Which is the power module for the 1400. This is about a $50-60 US part so I don't think you can go too wrong.Here is one of the links that shows these as 2 separate items for ordering.
http://perksystems.com/aironet1400.htm
Hope this helps!
Rob
Please remember to rate helpful posts .....
RaveDave1 Fri, 02/10/2006 - 10:06
Thanks for the info. Added it to the order for my customer.
Cisco's web site has almost no info on this. I searched for over 2 hours yesterday, trying to see if there was some combination of search parameters that would give me the info or if there was a 1400 document that would help. No luck.
Rob Huffman Fri, 02/10/2006 - 13:56
  • Hall of Fame,
    Founding Member
Hi RaveDave,
You are not kidding! I have trouble finding info on the site as well. It is like an art trying to manouver your way around.Let us know when your equipment comes in and you have evrything back up and running,whether this was indeed the right part. Just for future reference.
Take care!
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
