problems when load testing a cluster on CSS11501
Feb 9th, 2006
Hello there,
I have the following setup:
INTERNET <--> CSS11501 <----> SERVER CLUSTER
Vlan address of server cluster is in the same subnet of that of the CSS. server's gateway is IP of CSS. My problem is when we do load testing on each server, it goes well with no errors. but when we do the load testing using the VIP address of the cluster, the load testing app gets a timeout when getting the flash content of the cluster.
my config on the content is:
content BGUIDE_NEW
vip address 192.168.8.4
protocol tcp
port 80
balance leastconn
advanced-balance sticky-srcip
add service SRV1
add service SRV2
add service SRV3
add service SRV4
active
Is there anything lacking in my content config that I need to do? Where else in the config do I need to look at.
Thanks in advanced.
JC
Gilles Dufour Fri, 02/10/2006 - 00:10
  • Cisco Employee,
is your testing tool in the same subnet as the servers ? If so, you need a group to do client nat.
Are all connections failing or just some of them ?
Get a sniffer trace and you should see where the problem is.
Gilles.
cheng.j Sun, 02/12/2006 - 14:40
Testing tool is outside the subnet/network. Only the particular file cannot be loaded. I haven't used any sniffer programs yet. Should I install it on one of the server in the cluster? What do I look for on the trace.
Sorry about this. I haven't used sniffer programs yet.
