What is the difference between WIC and HWIC
basil-emircom
could any one please explain to me the difference between WIC and HWIC
for example if we want to configure the 2811 router we can choose
HWIC-4T which contain 4 serial ports
or
WIC-2T which contain 2 serial ports
other than the number of ports what is the difference
thanks
6 Replies 6
pkhatri
Level 11
Level 11
The HWIC cards support a much greater bus bandwidth (400 Mbps) than the WIC cards. Therefore, they are able to support a much higher port density than and greater speeds than the WICs. You can insert WICs in HWIC slots but not vice versa.
It also has a third row of pins, supporting power over ethernet and Cisco inline power. You can also get them in two form factors - single-wide or double-wide.
Hope that helps - pls rate the post if it does.
Paresh
thank you Pkhatri,
but let's talk mor specific as i said
for example what is the difference between the
and
both of them serial is there is any diference other than the number of ports??
speed for example?
Ok,
Yep, there are some differences apart from the number of ports.
The HWIC-4T can support up to 8Mbps on each port at the same time (for a total of 32 Mbps) on all supported platforms (it's not supported on the 1800 series routers).
The throughput possible on the WIC-2T depends on the platform it is installed in:
* Supports one port at 8 Mbps when used in NM-1FE1R2W, NM-1FE2W, NM-2FE2W, or NM-2W, or Cisco 2600 chassis WIC slots. All other WIC ports on that network module or Cisco 2600 chassis must not be used.
* Supports two ports at 4 Mbps each when used in NM-1FE1R2W, NM-1FE2W, NM-2FE2W, or NM-2W, or Cisco 2600 chassis WIC slots. All other WIC ports on that network module or Cisco 2600 chassis must not be used.
* Supports 8 Mbps on all ports simultaneously on 2691, 3725, and 3745. No restrictions. Maximum six ports at 8 Mbps each.
Paresh
Hi Paresh,
thanks for the info
from where can i read such these information
which documents should i read ?
thanks
Hi Basil,
There is really no better place than the data sheets for the products.
Here are links to the relevant datasheets:
(HWIC-4T) http://www.cisco.com/en/US/products/ps5949/products_qanda_item0900aecd80274424.shtml
http://www.cisco.com/warp/public/107/wic-2t.shtml
Hope that helps,
Paresh
I think this question this thread is well answered and can be closed. You said that the bus has 400Mbps bandwidth and the 4T card can take 32Mbps, and that is the complete answer.
